93 accord radiator fans
93 accord
thermostat switch brings only one fan while at idle. Jump connector and it brings up both fans. Having a hard time figuring out why only the radiator fans coming on and not along with the condenser fan. |
If you tap on the condenser fan when the thermostat switch turns on the radiator fan, will the fan run?
Originally Posted by PAhonda
(Post 398046)
I haven't tried , temperature gauges getting about 3/4 of the way so been trying to be careful. Temp gun reading only shows about 190. Where is the sensor for the gauge located? |
The temp sensor is a single wire sensor under the distributor near the upper radiator hose.
Do both fans turn on when you turn on the a/c with the engine running? Does the temperature go down when the car is moving? |
Haven't tried driving the vehicle. Its My aunts car. Need to check to see if the ac even charged as the fans do not come on when turning on the ac
