93 accord radiator fans
Old Sep 5, 2022 | 10:21 AM
Jaronh19's Avatar
Default 93 accord radiator fans
93 accord
thermostat switch brings only one fan while at idle. Jump connector and it brings up both fans. Having a hard time figuring out why only the radiator fans coming on and not along with the condenser fan.
Old Sep 6, 2022 | 08:16 PM
If you tap on the condenser fan when the thermostat switch turns on the radiator fan, will the fan run?
Old Sep 6, 2022 | 08:19 PM
Jaronh19's Avatar
I haven't tried , temperature gauges getting about 3/4 of the way so been trying to be careful. Temp gun reading only shows about 190. Where is the sensor for the gauge located?
Old Sep 6, 2022 | 08:34 PM
The temp sensor is a single wire sensor under the distributor near the upper radiator hose.
Do both fans turn on when you turn on the a/c with the engine running?
Does the temperature go down when the car is moving?
Old Sep 6, 2022 | 08:42 PM
Jaronh19's Avatar
Haven't tried driving the vehicle. Its My aunts car. Need to check to see if the ac even charged as the fans do not come on when turning on the ac
hlockquiok
Jan 14, 2020 10:04 AM
longdistance
Nov 24, 2015 07:14 PM
onemandeep
Jan 30, 2014 04:49 PM
gingle37
Jun 25, 2011 02:22 PM
jackfast
Feb 13, 2011 05:43 AM
