93 accord se
Old Nov 27, 2012 | 08:22 PM
iron horse 78's Avatar
Default 93 accord se
my 93 accord se had codes 6, 7 ,and 12.. took care of problems has no codes now but still the idle jumps high to low constantly and cant figure it out? any tips?
Old Nov 27, 2012 | 08:27 PM
I moved your help question here to get some responses.
Welcome to the forum, please take the time to read the forum rules, and do not post help questions in the DIY section.
Old Nov 27, 2012 | 10:57 PM
thanx
Old Nov 28, 2012 | 06:50 PM
If you removed the ECT (code 6) you lost some coolant. Be sure to properly bleed the cooling system as air in that will cause the IACV and or the FITV act funny causing the rpms to bounce between....1,000 to ~ 1,800.
Does this happen when the engine is warm, cold or all the time?
Old Nov 29, 2012 | 04:43 AM
thanx for da info! will try and let you know da out come!
