93 accord troubles
Old Jun 25, 2009 | 12:20 PM
54panman
Default 93 accord troubles
hi all im the panman a harley/hotrodder!!! but i have a 93 accord that im havn some troubles with! 93 accord 4 door power everything 2.2 efi auto tranny, still get about 23mpg (but i think it could do better.... now the trouble im having is low idle... 4-500 rpm both in park and stopped at a light! with real bad vibration... when i check timing mark to day the white mark was about 1/2" above my pointer! ive read all kinds of stuff and some say adjust the dist other say i cant, well my dist is a fixed unit pretty dan sure it aint moven!!! so what do i do next? it falled smog about 2 month ago with high idle and the say the h/c were about maxed out any higher and they would fail too. so any ideas i gotta get this fixed and reg'd asap so my girl can keep driven it!!! thanks panman
Old Jun 25, 2009 | 12:55 PM
54panman
correction!!! the dist does move i lossened it and turned it towards the front the the car and it brought my idle up about 80-100 rpm's but its still low and rough while in gear??? thanks panman
Old Jun 25, 2009 | 02:38 PM
Mikebike125's Avatar
My '93 has always shook when idling since I first got it even after tune ups and other fixes. I believe they all do it unless the idle is set too high. Setting it too high will cause other problems so I recommend setting it per the spec.
Old Jun 26, 2009 | 06:25 PM
deserthonda's Avatar
does engine miss on any 1 cylinder ?? i would chk the secondary system,,,,,( plugs, wires, cap, rotor, ) if all ok, the throttle body might be dirty , chk all the mounts,( but even if mounts are broken , that would not give you a low idle ) the timing mark is the red mark on the flex plate lined up with the pointer , if you cannot get the red mark to line up with the pointer cam timing might be off,, ...
idles rough, HC too high ,, sounds like you got a miss on the engine ...cam timing off ??
Old Jun 27, 2009 | 10:44 PM
HondaAccord93's Avatar
What about checking and adjusting the Idle Air Control Valve on the throttle body?
Old Jun 28, 2009 | 03:14 PM
54panman
thanks all i smogged it & it failed! passed everything timing(@ 22btdc) and nox levels around 1300-1400.... so i checked all the basics! and the egr(seemed ok) and ended up replacing plugs & wires and two can of carb cleaner down its throat! and a pint in the tank!!! then went and drove it bout 30 miles ran awsome!!!! great idle no vibration!!! till i got home parked in the drive and the tach started bouncing! wtf. now it still seems too run better but im back to sq 1? i dont get it! been reading bout the 6 little egr plugs and drilling them out and cleaning'em and all that good stuff? any thoughts thanks
Old Jun 28, 2009 | 06:55 PM
High NOX would point to the egr ports being plugged. Google T2T013.pdf for some instructions or the at fax on tegger.com may have some more information.
You car will run better with those ports cleaned. The EGR valve should not have vacuum when you are at idle.
Cleaning and tightening the FITV (search the forum, lost of posts about this) may eliminate the surging idle.
Also bleed any air out of the coolant system (make sure engine is cold) by removing the radiator cap and opening the bleed valve on the thermostat housing. Allow any air to spit out and shut the valve when a steady stream of coolant comes out. The top off radiator.
Old Jun 29, 2009 | 07:42 AM
I thought base spark timing was more like 15 btdc. Too much spark advance will give you high NOx.
RoccOhh11
Feb 19, 2009 05:04 PM
JohnTaurus
Sep 10, 2008 08:31 AM
ruski9t
Aug 11, 2008 05:21 PM
IWL BCNU
Sep 9, 2007 10:07 AM
89HondaLegend
Apr 6, 2006 05:48 AM
