93' Antenna issues
Old Sep 5, 2008 | 06:01 PM
whereiszack's Avatar
Default 93' Antenna issues
Hi, I broke my antenna on my 93 EX and unplugged it from my new stereo that i installed. Now i have put a new motor and mast in and when i turn the key to on position and the stereo comes on, the antenna does nothing.
What triggers the antenna? Is it the stereo coming on that sends a signal to the motor? And should all stereos with an antenna in slot work or will the antenna only work with the stock tape deck?
I tried searching for an answer to this problem but no mater what I do I cannot get the search feature to return any results to me.
Thanks in advance,
Zack
Old Sep 5, 2008 | 06:06 PM
finch13's Avatar
Default RE: 93' Antenna issues
The stereo should have a hole or cord to plug the antenna cord into. The wiring harness for your stereo should have an antenna wire and and amp wire, both are usually blue and one has a white stripe on it. The deck sends a signal out when you switch the deck over to Tuner that raises the antenna.
Old Sep 6, 2008 | 12:48 PM
Thanks. Now I just have to find a wiring harness diagram
Eauxkie
Sep 27, 2006 08:18 PM
billyloon
Jul 30, 2006 07:13 PM
msmiz
Dec 22, 2005 09:05 PM
stigedis
Dec 4, 2005 10:12 PM
pgopalak
Dec 17, 2004 03:30 PM
