93 Honda Accord
Old Jun 23, 2015 | 02:27 PM
Dirtdawg625's Avatar
Default 93 Honda Accord
I have a 93 Honda Accord It is not getting spark to the plugs. I have replaced the plugs, Plug wires, distributor cap, and Coil. The loss of spark came after washing the engine. It has been a week now and I can not seem to pinpoint the problem. Can anyone help with this issue?
Old Jun 23, 2015 | 08:34 PM
Try checking for engine codes. See the common diy thread on top of the gen tech help forum.
Old Jun 24, 2015 | 12:55 PM
Turtlehead's Avatar
The old washing the engine routine... Depends if you had the key on and listening to the radio which opens a few more doors. Could be a short some place or faulty ignitor that just so happened to fail at the same time. You need to chase the hot feed with a test light or continuity light and repair any opens and then chase the grounds. Don't leave anything in the ignition sequence out, including fuses and grounds.
