94 Acc LX - A/C Expansion Tube?????
Old Jul 19, 2012 | 11:05 PM
skimom33's Avatar
Default 94 Acc LX - A/C Expansion Tube?????
94 Accord LX 4-dr
Took the car to a mechanic/friend.
Pulled (vacuumed) out all the R134 that we had overfilled - or at least we THOUGHT we had overfilled - turns out its supposed to take up to 23oz, and we only put in 2 bottles.
The "whooshing" sound is gone, but the system will not circulate the R-134. Compressor IS working.
Low pressure is reading 0, even when the R-134 is replaced, but high pressure also drops to 0 when compressor initiates.
Mechanic is wondering if its the expansion valve assembly (if there is something clogging it).
Any suggestions on how to narrow that down?
Old Jul 19, 2012 | 11:14 PM
skimom33's Avatar
OoooppSS!!! Thats compressor, not condensor! So everything SEEMS to initiate to circulate the R-134, but its just not circulating.
And if its NOT the expansion valve, how do we find out which tubes it would be? Its there a way to diagnose this?
Old Jul 20, 2012 | 07:50 AM
Is the compresssor clutch plate engaging and turning? If not, no cooling can be obtained and an electrical problem is likely.
If compressor is engaging, but shutting down (Hi/Lo cutout switch will disable if too low), then a blockage is likley. Was receiver/drier replaced? Check for a cold receiver/drier. This would indicate big pressure drop across reciever/drier and blockage.
You may have to pull the evaporator and replace expansion valve if blockage is not in the receiver/drier.
wheresbrando
Apr 10, 2012 11:00 AM
cesar730
Apr 6, 2008 02:28 AM
z3kracer
Nov 7, 2007 08:02 PM
joeaksa
May 13, 2007 10:39 PM
ballistic
Aug 27, 2006 05:56 PM
