94 accord abs light help
Old Dec 8, 2012 | 12:46 PM
mcwk1992's Avatar
Exclamation 94 accord abs light help
I have a 94 accord that has abs light on. When I do the test with paperclip to wire abs light flashes 1-8-4-4-1-8. I am not sure how to read this
these are possible codes?
(94-97) ABS DTCs...
1 - ABS pump motor over-run
1 2 ABS pump motor
1 3 high pressure leakage
1 4 pressure switch
1 8 high pressure system
2 1 parking brake
3 1 pulser RF
3 2 pulser LF
3 4 pulser RR
3 8 pulser LR
3 12 different diameter tires
4 1 wheel sensor RF
4 2 wheel sensor LF
4 4 wheel sensor RR
4 8 wheel sensor LR
5 - rear wheel lock - R/L
5 4 rear wheel lock - R
5 8 rear wheel lock - L
6 - fail-safe relay - F/R
6 1 fail-safe relay - F
6 4 fail-safe relay - R
7 1 solenoid - RF
7 2 solenoid - LF
7 4 solenoid - R
8 1 ABS function
8 2 CPU comparison
8 4 IC self-check
Old Dec 8, 2012 | 12:59 PM
If I read this correct.....
1-8 High pressure
4-4 Right/pass rear abs sensor
Old Dec 9, 2012 | 10:57 AM
There's also different length pauses between flashing. So it should be like this...?
1 flash - short pause - 8 flashes
long pause
4 flashes - short pause - 4 flashes
long pause
93Accord2.2
Nov 7, 2013 07:10 AM
brayner
Feb 12, 2013 06:59 PM
mickey4live
Jul 6, 2012 08:29 AM
armstrong2010
May 6, 2011 12:14 PM
anthonyj89
Sep 24, 2008 10:20 PM
