94 accord d4 tcm code
Code 15 is Mainshaft Speed Sensor (MSS) circuit fault. It could be sensor, wiring, connector, or ECU causing the fault. Most likely MSS. If you want to diagnose, download the 94 Accord Manual from Online Manuals links in DiY forum.
MSS connector is on front side of engine, near trans dip stick. There are two wires; org/blu and wht/blu. Find connector and trace to MSS.
Short the same connector and count the ABS code(s). ABS light flashes a main code and sub-code. So a 4, then 1, is a code 4-1.
The vehicle speed sensor and the mainshaft speed sensor are different. You should download a 94 shop manual to show you the locations. The common DIY thread on top of this forum has a link to that online shop manuals thread.
no the brake lamp as it is spelled on the dash along with the abs light. only turns on when brake depressed if left in park the lights do not come on. i replaced the brake light switch checked fuses and fluid levels all are good samer with all rear brake lights all are functioning
