94 accord d4 tcm code
Old Jul 22, 2011 | 12:53 PM
mikekjr26's Avatar
Default 94 accord d4 tcm code
The trouble code is 1 long and 5 short can anyone tell me what this code is thanks
Old Jul 22, 2011 | 01:28 PM
Code 15 is Mainshaft Speed Sensor (MSS) circuit fault. It could be sensor, wiring, connector, or ECU causing the fault. Most likely MSS. If you want to diagnose, download the 94 Accord Manual from Online Manuals links in DiY forum.
MSS connector is on front side of engine, near trans dip stick. There are two wires; org/blu and wht/blu. Find connector and trace to MSS.
Old Jul 22, 2011 | 01:33 PM
mikekjr26's Avatar
is that the same as the trasmission speed sensor. I have replaced all shift solenoids and the TSS. the symptom is not knowing wether to be in 3rd or 4th gear rest of gears shift no problem
Old Jul 22, 2011 | 01:53 PM
Trace wiring and see if it's same one you replaced. I don't think it's same.
Old Jul 22, 2011 | 02:42 PM
mikekjr26's Avatar
its not i just looked at it and cleaned it. not sure of the results might be bad. thanks for your help
Old Jul 22, 2011 | 02:46 PM
mikekjr26's Avatar
i also have a brake lamp on and the abs light. all rear lights work perfect i replaced the brake light switch on the pedal assembly with no affect. can you help???
Old Jul 22, 2011 | 03:23 PM
Short the same connector and count the ABS code(s). ABS light flashes a main code and sub-code. So a 4, then 1, is a code 4-1.
The vehicle speed sensor and the mainshaft speed sensor are different. You should download a 94 shop manual to show you the locations. The common DIY thread on top of this forum has a link to that online shop manuals thread.
Old Jul 22, 2011 | 03:53 PM
mikekjr26's Avatar
abs code is 1-2
Old Jul 22, 2011 | 04:06 PM
Is the brake light that turns on the one that lights up when you turn on the emergency brake?
Old Jul 22, 2011 | 04:17 PM
mikekjr26's Avatar
no the brake lamp as it is spelled on the dash along with the abs light. only turns on when brake depressed if left in park the lights do not come on. i replaced the brake light switch checked fuses and fluid levels all are good samer with all rear brake lights all are functioning
