'94 Accord LX - Dash Light Replacement?
I have a '94 Accord LX Auto. A couple of the dashboard lights are out which makes the speedo tough to see at night. Is it easy to remove the dash and replace the lamps?
Thanks- Dan :) |
RE: '94 Accord LX - Dash Light Replacement?
ORIGINAL: Dshow I have a '94 Accord LX Auto. A couple of the dashboard lights are out which makes the speedo tough to see at night. Is it easy to remove the dash and replace the lamps? Thanks- Dan :) you got to remove the center console , the stereo , to get access to some screws to remove the panel, disconnect some plugs, pop out a few switches , there are hidden screws behind them, pry out on the panel carefully not to snap it, once panel is out , there are 4 screws that hold the instr cluster in place, disconnect plugs from the rear and remove cluster,, the bulbs are on the back side, replace as needed |
Is there any kind of diagram that would show the location of the screws etc? Maybe one of those free online service manuals? Thanks for you help.
if you go to our DIY section there are links to get online manuals
| All times are GMT -5. The time now is 11:59 PM. |
