'94 Accord LX - Dash Light Replacement?
Old Aug 19, 2006 | 02:35 PM
Dshow's Avatar
Default '94 Accord LX - Dash Light Replacement?
I have a '94 Accord LX Auto. A couple of the dashboard lights are out which makes the speedo tough to see at night. Is it easy to remove the dash and replace the lamps?
Thanks- Dan
Old Aug 19, 2006 | 02:58 PM
deserthonda's Avatar
Default RE: '94 Accord LX - Dash Light Replacement?
ORIGINAL: Dshow
Thanks- Dan
no need to remove the dash, but you got to remove the instrument cluster and the job itself is not too bad,,
you got to remove the center console , the stereo , to get access to some screws to remove the panel, disconnect some plugs, pop out a few switches , there are hidden screws behind them, pry out on the panel carefully not to snap it, once panel is out , there are 4 screws that hold the instr cluster in place, disconnect plugs from the rear and remove cluster,, the bulbs are on the back side, replace as needed
Old Aug 19, 2006 | 06:43 PM
Dshow's Avatar
Is there any kind of diagram that would show the location of the screws etc? Maybe one of those free online service manuals? Thanks for you help.
Old Aug 20, 2006 | 04:19 AM
if you go to our DIY section there are links to get online manuals
OneEyed
Jun 25, 2015 05:32 AM
victorywhity
Mar 24, 2011 09:37 PM
rloden
Apr 4, 2008 08:56 PM
ivrex
Dec 10, 2006 03:24 PM
