Starter question... and yes this has probably been asked before
Old Aug 18, 2006 | 11:05 PM
LostinMaine
Default Starter question... and yes this has probably been asked before
I understand that there are two types of started for the accord but i was wondering what the difference is between the auto and 5speed starter and are they interchangeable?
Old Aug 19, 2006 | 12:48 PM
lightshow's Avatar
Default RE: Starter question... and yes this has probably been asked before
i think they are the same but not sure. when i bought mine i definately told the store that my car was a manual.
Old Aug 19, 2006 | 02:00 PM
sir_nasty's Avatar
I believe they are sort of interchangeable but my guess would be that one is a touch stronger than the other since your flywheels should be slightly different in weight from auto to 5 speed.... but I'm just guessing...
Old Aug 19, 2006 | 07:58 PM
I don't think it's strength or flywheel weight. The load on the starter would be about the same because it's mostly determined by the engine itself.
I always figured the mounting flange & bolt spacing were different, but don't know for sure.
Old Aug 20, 2006 | 11:58 AM
sbclemens's Avatar
I had recently replaced my starter for an AT. The parts department at first brought out a starter for a manual transmission. There is about a 1/4 inch difference between the bolt patterns. You may not be able to get the starter mounted properly.
HondaAficionado
Oct 18, 2011 07:50 PM
ebarrera661
Sep 29, 2011 05:39 PM
techstep
Oct 4, 2009 10:28 AM
live2rice
Apr 5, 2009 09:28 PM
fireballer44
Sep 11, 2006 11:08 PM
