94 Accord vtec drives fine, dies at a stop
I just got a 94 Accord EX that drives fine, but if I am driving +20 and come to a complete stop the RPMs dump to 0 and the car sputters and dies. It starts right back up and then will idle at the stop fine.
Yes, go here: https://www.hondaaccordforum.com/for...threads-40780/
Scroll down to the 5th gen section and there is a link.
Do you mean the entry/exit ports on the TB? I cleaned the IACV but I should of done a better job. When I pulled it away from the TB I noticed alot of gunk built up on the screened hole. I thought that if I got rid of that it might fix it, so I will have to remove the IACV and clean it up real good.
Yeah, if there's gunk there, you can probably assume there's similar gunk through the IACV itself.
Over in the DIY section there's a post about setting the base idle & having the system re-learn the idle.
