94 accord won't start?!?!
Old Nov 15, 2007 | 05:24 PM
Jahsaccordcoupe's Avatar
Default 94 accord won't start?!?!
My 94 accord cut off on me as I was going down the road at about 30-35 miles an hour and now it will not get spark....I tried a new coil nad a new distributor but still no spark...what else could be the cause of this?
Old Nov 15, 2007 | 05:29 PM
deserthonda's Avatar
Default RE: 94 accord won't start?!?!
make sure that the t-belt is ok,
remove the oil filler cover, have someone crank the engine and see if the rocker arms move up and down .. also,, did new distr come with a new ignitor ??
And on a final word of advice ,, NEVER replace parts till you properly diagnose the problem ..
Old Nov 16, 2007 | 08:46 AM
Yes I got everything....new rotor button and cap,everything is turning rockers, cam and all there is just no spark comming from the coil......Is there any relays that may be gone bad or something?
Old Nov 16, 2007 | 10:29 AM
You can start by checking whether there's power at the distributor. Maybe a yellow/black wire? (DH will know, I don't have a '94.) It should have battery voltage when the key is at "ON" or "START".
Old Nov 16, 2007 | 05:58 PM
Thank you to all who have tried to help me with this problem the main relay under the dash was the problem it starts and runs a hell of alot better than before...again thank you all!!!
Old Nov 17, 2007 | 03:40 PM
Thanks for the update.
That's first case I've heard of Main Fuel Relay (MFR) failing while driving. Note, MFR would not cause loss of spark, so maybe two problems at same time or intermittent problem (keyswitch perhaps) that may return.
Old Nov 17, 2007 | 04:05 PM
ORIGINAL: Jahsaccordcoupe
Now that's aNew one for all us members to remember..I was gonna relate to that question , but he beat me to it first
Tony1M
Nov 6, 2023 08:29 PM
Sheri6889
Jun 17, 2015 08:19 AM
conankun411
Dec 12, 2005 11:38 PM
dgeorge
Nov 29, 2004 01:40 PM
