94 lx dies after turning on
Old Jan 10, 2008 | 04:10 PM
jose310's Avatar
Default 94 lx dies after turning on
im thinking is something with the throttle body, wen i turn it of and wait 5m and try to turn it on again it wont, it just cranks or it will turn on but die in a sec, i pressed on the gas pedal while cranking and it turned right on, i have the throttle body sensor broken and its loose can that be the problem? any advice? this just happened today
Old Jan 10, 2008 | 05:09 PM
nafango2's Avatar
Default RE: 94 lx dies after turning on
try putting it back on tight and see what happens i guess, dont see how that could stop it from starting though.
Old Jan 10, 2008 | 05:44 PM
sir_nasty's Avatar
when you pressed on the gas pedal did you go like half throttle or all the way down?
Also, what sensor is broken and by broken do you mean the plastic casing or what is wrong with it?
Old Jan 10, 2008 | 05:51 PM
jose310's Avatar
i just went have ways on the pedal, and the case is broken,the clip,the throttle sensor just slides right of, i also have that surging idle prob, can that be the cause?
Old Jan 10, 2008 | 06:29 PM
HondatechAV6's Avatar
half or full throttle enters clear flood mode. a bad tp sensor doesn't help your problem. you have a multitude or problems, fix them one at a time. first start with a new tp sensor. next, see if the starting problem is still there. if it isn't fix the surging idle.
Old Jan 10, 2008 | 06:49 PM
jose310's Avatar
how much are the tbs?
Old Jan 10, 2008 | 06:50 PM
sir_nasty's Avatar
go take a look... I don't know off the top of my head...
www.hondaautomotiveparts.com
Old Jan 10, 2008 | 07:30 PM
jose310's Avatar
ok, thanks but my main concern is the starting issue, i wanna know wats causing this problem? i went outside to start up the car and it started fine , but at 2000 rpms and it stayed there for a good while then it started surging.
Old Jan 11, 2008 | 03:40 PM
I don't know if the throttle sensore is the problem. Is this the sensor that is on top of the TB (MAP sensor) or the one that is behind the TB against the firewall (throttle position sensor)?
Is your check engine light on? To find codes go to the DIY section under ACC 5th gen... and there is a link on that dhost page that has CEL instructions.
Old Jan 11, 2008 | 05:21 PM
Last time I checked, the Throttle Position Sensor was not a replaceable part on the throttle body; i.e. honda wants you to buy a new throttle body assy. In principle, it should be possible to replace this, but you would beon your own to adjust the new sensor. Probably something to do w/ pollution controls is why they ruled out replacement.
I've never had or read of anyone whose had a bad TPS, but it should be possible for it to cause a fault. There is a specific obd1 code (8)) for TPS. If you don't have this TPS may not be your problem.
TPS is on the throttle body linked to the throttle plate shaft.
A used throttle body from a salvage yard may be best bet. Check car-part.com for used parts near your zip.
Correction: Code 7 is Throttle Angle (or Position) Sensor. Code 8 is TDC sensor.
