94 LX Rides Like a Pair of Moon Boots!!!
So after fixing all me electrical issues with my car, I need to tackle the suspension, and I could use some suggestions. The problem is mostly with the rear. When I hit a bump or rough spot at low speeds, like driving through a parking lot, I feel like I知 driving a pogo stick for about 5-10 seconds. At higher speed, the bounce is not as violent, but it feels like the car is floating up and down and like I could lose control any second. If this happens when turning (like getting on the interstate on-ramp), it feels like the rear end slipped on a banana peel and barely caught itself lol.
so, I知 thinking shocks, but I知 not sure if there痴 something else these symptoms indicate or not. Mostly due to my lack of knowledge when it comes to describing the symptoms in a way that leads me to clear answers, as you can probably tell by now.
As for the front, there痴 a slight shake or wobble on the right side at high speeds. Perhaps a tie rod end? I知 going to the pull-a-part tomorrow so any suggestions on things I could get would be greatly appreciated!!!
I’m hoping to find some that look like they were recently replaced. I know there’s not a huge chance I’ll get that lucky, but since I’ll be there already (they’re having 40% off everything), I figured it may be worth a shot as long as I can look them over to make sure they look like they’re in good condition
im mainly looking to make it better than in is now. I’ll hopefully be buying brand new in a couple months but I would like to feel at least marginally safer until then.
Those strut assemblies are often fairly chintzy. Chances are the coils are fine and only the struts need replacing. I would replace the struts with a quality brand such as Bilstein, KYB, or Koni. Stay away from the cheap brands unless you only plan to keep your car for a short while. I bought the KYBs from Shock Warehouse.
" no need to pay KYB premiums for such an old car. "
very true!!! (unless you plan on keeping the car).
the monroes only last approimately half as long as the kybs .... check out the kyb prices on Shock Warehouse
An odd statement to say the least. If anything I would say KYBs, on average, have a shorter lifespan than comparable Monroe shocks and struts. Regardless, none of the aftermarket units seem to last anywhere near as long as OEM equipment, so if longevity is the goal, buy from Honda direct.
Shipo
We can agree to disagree, all in good fun. Like the Corsair, BTW.
Over 40 years of experience with many brands of shocks/struts. I gave up on Gabriel and Monroe years ago, due to them not lasting. In all fairness, I haven't tried them in years so maybe their newer products are better.
My personal preference is Bilstein or Koni, even over the OEM. In general, the KYB products are not as good as those two.
Also, the Honda struts are good quality.
KYB vs Monroe:
https://cozystream.com/kyb-vs-monroe...ews-different/
https://www.bobistheoilguy.com/forum...s_KYB....again
https://community.cartalk.com/t/qual...orbers/94367/7
from the above link:
"BTW, I was an engineer for a former GM division that made shocks and I’ve cut apart many brands of shocks and struts to see what is inside. Monroe is a bottom feeder especially their aftermarket replacement parts, Gabriel is a bit better, KYB, Showa and Boge/Sachs (now TRW) are better yet. All are OEM suppliers. Premium suppliers would be Koni or Bilstein."
KYB vs Monroe:
I ended up not getting any from the yard today. I will probably end up getting new ones when I can afford them. I was really just needing some to last at least a few weeks, and figured if I could get them for $9 each it may be worth it. It will most likely be at least a month before I can get new ones, but hopefully I can make it until then with the ones I have.
its been a hell of a month having my accord on the fritz since I got it, then having it and 2 other cars break down within two days. I’ve learned a lot though, so at least there’s that.
forestcd6
Apr 10, 2010 08:46 PM
richomundo
15
Jul 18, 2008 06:15 PM
