95 Accord ABS
Old Mar 28, 2008 | 11:50 AM
dacecil's Avatar
Default 95 Accord ABS
I have a 95 Accord EX V-6 with ABS. The light is on and stays on. I have done the trouble shooting as described in the Snap On scanner- removed fuse etc. I also installed a new ABS computer but the light is still on. Any ideas on how to fix this or to at least narrow down what the problem is? Oh, and the ABS fuse box shows on the cover to have a 40amp ABS motor fuse, but mine doesn't have one in there. I jumpered across the screws that appear to hold it in, but still nothing.
Thanks,
Dale
Old Mar 28, 2008 | 12:54 PM
Default RE: 95 Accord ABS
do you know what the code is?
Old Mar 28, 2008 | 05:38 PM
Chiovnidca's Avatar
Yep, need a trouble code.
Old Mar 28, 2008 | 05:59 PM
MichaelT1960's Avatar
Check the fluid level in the reservoir....it may be low from it leaking out...
a common problem. The plugs leak over time.
michael
93Accord2.2
Nov 7, 2013 07:10 AM
MichaelEXL
Dec 5, 2005 03:46 AM
kwp1229
Sep 22, 2005 04:57 PM
shinobi16
Aug 7, 2005 09:43 PM
Jun 30, 2005 12:33 AM
