95 accord ex, ABS light, question
Old Oct 16, 2008 | 01:55 PM
d_zone21
Default 95 accord ex, ABS light, question
Its for a 95 accord ex 4cyl auto, My Abs light comes on after a minute of driving, i checked my brakes and they are still good, my brakes sqeeks just a little. The brakes is just functioning the way it should be (i think), what could it be? is it my sensor? if it is where do i find it and fix it? is it expensive?
Thank you
Neiser
Old Oct 16, 2008 | 02:13 PM
Default RE: 95 accord ex, ABS light, question
there is more than one sensor that could set it off, bring it to autozone and have them run the code(free) and that will tell you what sensor is setting it off
Old Oct 16, 2008 | 02:17 PM
falkore24's Avatar
Look on TAS for prices of parts
Old Oct 16, 2008 | 04:25 PM
Since your other post is about the CEL & VSS problem, they are probably related.
When you jumpered the connector to read the CEL blinking, the ABS lamp should have also been blinking its own code. What was that?
I think the ABS will also throw an error if it cant see a good signal from the VSS.
Old Oct 17, 2008 | 12:30 AM
d_zone21
thanks alot, this will help me alot, and i really appreciate all your help. ill do that and see what happens, Ill take it to autozone to run the scan and see what happens.
Thank you
Neiser
Old Oct 17, 2008 | 07:12 AM
Autozone won't be able to help w/ an ABS code. It can only be extracted manually same way you extracted CEL code, but reading the ABS light flashes. All short flashes separated by short pause so ffff-p-ffff = 4-4. Post code for help.
Old Oct 17, 2008 | 08:00 AM
ABS has its own syntax of flashes too.
Long flash & long pause = not part of the errorcode yet.
short flashes = first digit of 1st error code
short pause
short flashes = 2nd digit of 1st code
long pause
short flashes = 1st digit of 2nd code
short pause
short flashes = 2nd digit of 2nd code
long pause
(I dont know how many codes can be stored)
then they repeat...
93Accord2.2
Nov 7, 2013 07:10 AM
brayner
Feb 12, 2013 06:59 PM
mickey4live
Jul 6, 2012 08:29 AM
anthonyj89
Sep 24, 2008 10:20 PM
tobybul
Jun 14, 2007 06:36 PM
