95 Accord EX-H22A swap help
Old May 27, 2012 | 04:10 PM
gb95accord's Avatar
Default 95 Accord EX-H22A swap help
Hello all,
Putting an h22a in my 95 ex. Everything is fine so far, just wont turn over, cranks but wont start. ECU supplied by hmotorsonline. My question is what could it be? everthing is hooked up. my h22a came with an internal coil dizzy and my ex had the same one. do i still need to modify wires? even swapped the resister box for the h22a one. any insight would be appreciated!
Old May 27, 2012 | 04:17 PM
First test would be to see if its getting spark, second test would be to see if its getting fuel.
Old May 27, 2012 | 05:02 PM
gb95accord's Avatar
My buddy who is a mechanic is working on it with me. It is getting fuel, just no spark. Just trying to start the process of elimination. Since I have an 95 ex, the internal coil h22 should work fine, correct?
Old May 27, 2012 | 06:32 PM
crispin's Avatar
If that is the wiring harness you are using then it is fine, the ECu does not care which one you use just as long as all the wires are connected.
Old May 27, 2012 | 06:36 PM
Check that the blk/yel wire to the distributor has 12V when the key is in the II position.
I would also check for engine codes. See the link in the common diy thread on top of the gen tech help forum.
Old May 28, 2012 | 06:10 AM
I'd also check the main ground (g101) on the end of the tb - at least that is where it is on the stock engine...
Old May 28, 2012 | 10:02 AM
gb95accord's Avatar
Thanks for your responces so far guys. I'll give it a look today!
Old Aug 29, 2012 | 08:31 AM
Ryanpavelchik's Avatar
Maybe this is too big a question but here goes:
how much should i pay to have an H22a swap done for my 95 LX (i assume it needs the corresponding transmission). i'm new to honda accords. i've had and done everything to toyota trucks for the last 20 years. i can do anything on those. if hondas are as easy to work on as toyotas with the 22re, i could do it my self.
Old Aug 30, 2012 | 05:58 PM
If you can do "anything" with Toyota's....the Honda shouldn't be that much different. Just add that it is a front wheel drive.
sakerut
Feb 7, 2011 04:16 PM
hitek85
Feb 12, 2008 10:32 AM
maro
Apr 11, 2007 06:53 PM
maro
Apr 11, 2007 06:51 PM
noboundaries6289
Feb 15, 2007 02:06 PM
