95 honda accord
Old May 3, 2006 | 04:43 AM
kid
Default 95 honda accord
can anybody help me i have a 95 accord automatic tran cant get car to go to any gear shifter wont move [>:]
Old May 3, 2006 | 11:59 AM
deserthonda's Avatar
Default RE: 95 honda accord
ORIGINAL: kid
is it stuck in park ?? If so, aply the brakes see if brake lites come on,, if not.. blow the horn, if it does not work replace the fuse and retry, if it works the brake fuse is fine, next thing is to jump the brake switch , on the brake pedal , thats where the switch is located, unplug the connector and jump together the wires, white/yellow and green/white, if it works, replace brake switch.
Try this and post results
Old May 3, 2006 | 10:55 PM
kid
tried jumping wires did not work thank u think of anything eles
Old May 21, 2006 | 04:03 PM
kid
went through checked fuses again found (ecu/cruise control/eat ecu/) 7.5 amp was a cheap lose fuse caused a lot of problems now able to get gear ****fer out , thought it was tranny problem,glad to have it running thanks Desert Honda
Old May 21, 2006 | 05:12 PM
glad that it is fixed........And many thanks for writing back and letting us know the fix.
