95 Honda Accord
Old Feb 20, 2010 | 06:42 PM
rrtvede's Avatar
Default 95 Honda Accord
95 Honda Accord - auto/4cyl vtec 150Km
2 items:
1. Drivers side output shaft seal leaks, new half shaft, replaced the seal 3 times, still leaks, Have installed flush with casting. Is it supposed to be inset or outset of the casting? Are there special installation requirements not described in the Honda shop manual? Other suggestion?
2. Brake fluid is being lost from the ABS resivoir, when filled and bled system works well. Leak is not apparent with no fluid trails or brake fluid found. Is there another route for the loss such as ingestion into the vacuum side of the motor...lost on this one.
Thanks
RRT
Old Mar 9, 2010 | 08:13 PM
I can't remember how the seal is set on the casting. I remember reading that a problem with the differential may cause a leak. If the new CV joint isn't seated properly, a leak could occur.
There is a bulletin about the ABS leaking and you tighten some plugs. I can't post pdfs. The TSB number is 96-050, so I am sure you can find a pdf of it by searching the web.
Old Mar 9, 2010 | 11:43 PM
deserthonda's Avatar
http://www.justanswer.com/uploads/Ho...214735_abs.pdf
