95 Honda Accord
Old Aug 22, 2011 | 08:07 AM
aCCord69's Avatar
Exclamation 95 Honda Accord
Ok, so im new to this sight, and forum but i know a little bit abt cars. except this problem. if you guys could help me out it would be much appreciated!
: okay so once i get up to above 30 mph the front left tire (driverside) starts to make a noise. but the thing is its only when i turn the steering wheel left. this happens especially when i take turns to the left at those speeds. i thought it would be the power steering pump fluid so i changed it but it still does it. the other side is perfectly fine though. i dont know what it is specifically but if anyone could throw me some advice that would be awesome. also i can feel it in the steering wheel. its not just a noise so it sounds like something is rubbing together. plzzz help, thank you guys
Old Aug 22, 2011 | 09:26 AM
bigpat's Avatar
Almost A Senior Member
Sounds like a bad axel or cv joint...Also check the wheel bearing for wear.
Old Aug 22, 2011 | 01:03 PM
I moved this out to it's own thread because it's very different from the thread you posted in.
