95 honda accord ex
Old Apr 11, 2012 | 08:39 AM
msffletch's Avatar
Default 95 honda accord ex
I have replaced every seal and gasket known to man in this engine and is still pouring oil. Just starting to wonder if the head gasket can leak a lot of oil and not cause anymore problems.
Old Apr 12, 2012 | 12:00 AM
I will move this incorectly posted message to the correct forum for you..
And yes it will ruin your car...
Old Apr 12, 2012 | 03:13 AM
Tyler Joyce's Avatar
So you have replaced every gasket but one of the most obvious ones? Change your head gasket. Where is it leaking from?
Old Apr 12, 2012 | 06:05 AM
Best way to check to see ift he head gasket is bad is to check the oil and see if it is milky or cloudy as coolant would likely be mixing with it as well.
Can you pinpoint and area where the oil is coming from?
Old Apr 12, 2012 | 08:13 AM
You need to pinpoint the location it's leaking from. After you think you find it, clean it up good then watch it leak to see if it's the correct spot.
It's possible but not common, for the headgasket to leak oil out but NOT leak coolant into the oil. Head gasket it a big, job, so I'd verify it's actually leaking before "just replacing it".
Old Apr 13, 2012 | 07:32 AM
msffletch's Avatar
Well theres nothing milky about the oil but still have to try to pinpoint where the leak is. Thanks for your help and I will keep you updated.
Old Apr 14, 2012 | 07:32 PM
kerooney's Avatar
it could possibly be the rear main seal....
