95 honda accord ex abs code 14
Old Feb 18, 2016 | 09:56 AM
DemiGodOdin's Avatar
Default 95 honda accord ex abs code 14
Hello i have 95 Honda accord ex with a vtec motor manual transmission in it and I recently saw that my abs light went on, I jumped the connector and it gave me a code of 14. One long blink and 4 fast blinks. I know that it is the pressure switch but when I go to look online to see where exactly it is in the car, I cant seem to find it. Does anyone know where I can find the pressure switch in this car and what I would have to do to it to get ride of the abs light? thank you for any helpful responses.
Old Feb 18, 2016 | 10:33 AM
The first long flash isn't part of the code. Here's the scheme for 1994-1997. Pay attention to the spaces between the 4 short flashes. I don't see a 2-2 code, but there is a 1-3 and a 3-1.
Insert the jumper, then turn on the key.
Long (2sec.) flash - long (2sec.) pause - this isn't the code yet.
Short flashes for the first digit of the code - 1sec. pause - short flashes for the 2nd digit.
Long (5-second) pause, then the next code.
(94-97) ABS DTCs...
1 - ABS pump motor over-run
1 2 ABS pump motor
1 3 high pressure leakage
1 4 pressure switch
1 8 high pressure system
2 1 parking brake
3 1 pulser RF
3 2 pulser LF
3 4 pulser RR
3 8 pulser LR
3 12 different diameter tires
4 1 wheel sensor RF
4 2 wheel sensor LF
4 4 wheel sensor RR
4 8 wheel sensor LR
5 - rear wheel lock - R/L
5 4 rear wheel lock - R
5 8 rear wheel lock - L
6 - fail-safe relay - F/R
6 1 fail-safe relay - F
6 4 fail-safe relay - R
7 1 solenoid - RF
7 2 solenoid - LF
7 4 solenoid - R
8 1 ABS function
8 2 CPU comparison
8 4 IC self-check
DemiGodOdin
Feb 4, 2016 02:57 PM
93Accord2.2
Nov 7, 2013 07:10 AM
bensminger2003
Mar 3, 2012 04:57 PM
ferrcad
Oct 20, 2011 11:45 AM
madsteez
Jan 18, 2009 07:43 PM
