95 LX Auto - hard shifts
Old Jan 11, 2008 | 01:03 PM
nafango2's Avatar
Default RE: 95 LX Auto - hard shifts
it may be corrected by adding a bottle of lubeguard, but that doesnt mean its recommended by HONDA. Consumerguide != honda.
the 94 and 95 accords were notorious for their harsh shifting, in 96 they reprogrammed the TCU to shift smoother.
i especially wouldnt trust a site that claims there is a "DC" model of the accord.
personally I wouldnt put lubeguard in my transmission even if it shifted hard. Im very skeptical of just about every additive out there. If honda wanted you to add something to the transmission they would make their own additive. Not tell you to use some other additive.
Old Jan 11, 2008 | 02:10 PM
Accord_Ras's Avatar
ORIGINAL: nafango2
That's very sloppy logic right there. Honda doesn't actually make any of the Honda brand fluids. They are made by third parties...some to stipulated specifications. Consumerguide was merely quoting an offocial honda SB....which I have actually seen myself. But, as I've said, I'm not going to quarrel with anyone. I would suggest that everyone does his or her research and not rely on so called "experts". At the end of the day it's your car....do with it as you please
Old Jan 11, 2008 | 02:23 PM
patpatpat's Avatar
I only use Genuine Honda Products. More expensive, but never caused problems either. Honda "sells" great fluid, whether it is for dirt bikes or cars.
Old Jan 11, 2008 | 02:56 PM
nafango2's Avatar
ORIGINAL: Accord_Ras
ORIGINAL: nafango2
Sorry man, but I cant find that TSB anywhere. Mind linking it?
Old Jan 11, 2008 | 03:02 PM
Gopal's Avatar
I called the local Honda dealer and requested to speak with the chief mechanic. That guy said the fluid change would not do much to improve the shifting quality, but will improve the transmission life.
So, the 95 Accord does shift harsh as a 'design', without causing damage to the transmission?
Old Jan 11, 2008 | 03:21 PM
Throttle control cable adjustment can have great impact on shift quality. There's a very detailed procedure, but not difficult, to adjust the throttle control cable at the trans throttle control lever end.
My 94 EX has 225K miles and shifts very smooth, IMO.
Old Jan 11, 2008 | 03:51 PM
  #17
Gopal's Avatar
ORIGINAL: TexasHonda
This is significant info. Thank you. I found this on the net : http://techauto.te.funpic.org/transmission.php
Added Oct-1-06 Problem: My car shifts harshly... when it shifts it jerks, a bad shift shock. What is causing it and how do I fix it?
Only for the computer controlled transmission. The transmission detects pedal dept via two points. One at the TPS and the other at the transmission. If the deeper you press the gas the less harsh it becomes then the problems lies on the out-of-adjustment at the transmission throttle cable.
Solution: Using a wrench, adjust the transmission throttle cable in small increments and test drive. Tip: The more the slack the harsher the shift.
Any links/hints/tips on where I should look for the adjusting the cable?
I think this is my problem, because with warmed up engine and at higher rpms it does shift smoother. Of course, I will be doing a fluid change as well.
Old Jan 11, 2008 | 04:33 PM
  #18
See the DIY tip for Online Manuals and download the 94-97 Accord manual from hondahookup.com. It should have the procedure in the transmission section.
Let us know how it goes.
Old Jan 13, 2008 | 01:38 PM
  #19
Gopal's Avatar
Great advise!
I removed the slack on throttle cable (just a bit) and the shifting improved. Not dramatically, but enough to make me feel better. I also noticed that the shift-points have changed and the car behaves a bit 'smarter', i.e., quicker response to accelerator.
I'll change the fluid and see if that removes the rest of the harshness...
Old Jan 13, 2008 | 06:54 PM
  #20
Gopal's Avatar
Default RE: 95 LX Auto - hard shifts - Update 1
OK, so I changed the fluid earlier today. Looks like the fluid was never changed before this. It was dark and a lot of particles on the magnetic lug. Wiped it clean, reinstalled and poured in fresh Honda fluid. The car already shifts better, when warmed up, I can hardly feel the 2-3 shift, even the 1-2 has improved.
I'll change fluid 4 times over the next one month. And then wait for about a 1000 miles to see where it is. I'll update on the news. I do not expect it to be 'like-new' but do expect a reasonable improvement.
Thanks everyone here...!
