95 Manual trans, upgrade options?
Can anyone tell me if there is a transmission that has possibly better gear ratios than the stock LX tranny in my 95? I have a bad axle bearing right now, but I'm wondering if it's even worth tearing apart to fix if there's something a little sportier out there. possibly EX?? Tahnks in advance.
RE: 95 Manual trans, upgrade options?
I think that both the EX and LX/DX manual transmissions are the same thing.
A prelude tranny would be geared differently and definitely sportier. I don't know enough about swaps to ensure you that there is a direct bolt-on for you accord. |
The H22 manual tranny has shorter gearing for better acceleration. A common thing to do is to use an H22 tranny with a F22 5th gear set swapped in for better gas mileage.
h series trannys will work on f series motors(minus the f20/22c). I ran a M2B4(JDM LSD Lude tranny) on my F for a while. You are looking for either the M2B4(LSD) or M2Y4(non-LSD) trannies
for example here are the gear ratios M2Y4: 1. 3.285 2. 1.956 3. 1.344 4. 1.034 5. 0.812 FD 4.266 M2B4: 1. 3.307 2. 1.950 3. 1.360 4. 1.034 5. 0.787 FD 4.266 P2A4(stock accord): 1. 3.307 2. 1.809 3. 1.185 4. .903 5. .685 FD 4.062 |
