95 Speedometer not working
Old Jul 19, 2009 | 09:20 AM
CarbonXe's Avatar
Default 95 Speedometer not working
I just bought a 95 Accord EX and when I took it for a ride yesterday, I noticed that the speedometer isn't working. When I start the car, it sits at about 18MPH. When I back up, it bounces a little between 10-18MPH and when I drive it just stays at 18MPH. No CEL on. Anyone have any idea? I'm going to be changing the brakes and wheels this weekend, so I guess I'll start at the wheel speed sensor, but has anyone heard/ran into this problem?
Old Jul 19, 2009 | 09:39 AM
hondadude's Avatar
Well, if you have no CEL then the most likely problem is the speedo head in the cluster.
Having no CEL indicates the Speed sensor is putting out the correct pulses.
Old Jul 19, 2009 | 02:52 PM
00AccordLX5spd's Avatar
Registered User
Does the cruise control work?
If no CEL it probably does. If it was the VSS, the CEL would likely be on and the cruise would not work. Also if you have an automatic, a faulty VSS would cause transmission shifting problems.
It is likely the speedo head within the cluster as hondadude said.
Old Jul 19, 2009 | 04:39 PM
Sounds exactly like what mine did when the speedometer itself stopped working.
Old Jul 19, 2009 | 09:28 PM
deserthonda's Avatar
Do not replace anything till you diagnose first
But is sounds to me like you got a bad speedo gauge
Old Jul 20, 2009 | 08:14 AM
Diagnose x2
If the speed sensor itself was bad, you'd have a check-engine light & your cruise-control wouldn't work.
Old Jul 20, 2009 | 08:46 AM
Registered User
Originally Posted by JimBlake
Diagnose x2
And the transmission wouldn't shift correctly if you have an automatic
Old Jul 20, 2009 | 12:49 PM
CarbonXe's Avatar
Thanks guys. Any way to easily fix it other than replacing the cluster?
Old Jul 20, 2009 | 01:07 PM
If you're lucky, it's loose/corroded wiring connections at the back of the cluster. You should check to rule that out, but don't hold your breath.
Old Jul 20, 2009 | 01:19 PM
Registered User
The hardest part will be getting the old cluster out since you have to remove the whole dash. Check the connections as JimBlake said.
The easiest route will be to either buy a used cluster off ebay (most will roll the mileage to whatever you want it rolled to) or send to a speedometer repair shop (can be found online - you ship them your cluster, they fix it, and send it back - probably run you $100 or a bit more).
if you take it to a honda dealer they will simply throw a new speedo unit in there (odometer is part of the speedo unit) and the odometer will show 0 miles.
