96 Accord intermittent cranking issue
Old Nov 28, 2011 | 08:55 AM
pordlawk's Avatar
Default 96 Accord intermittent cranking issue
This is my daughter's car, so I don't know all the specifics, but I do know I can't have her driving a car that won't start. Usually it cranks like a champ, sometimes not. Replaced starter (was tested, bad) 3 months ago, everything was fine until a month ago when battery started failing and replaced. Now in just the last week, some of the time when key is turned, nothing. Like the starter isn't even wired. No clicking, headlights don't dim, radio doesn't security lock out, all dash warning lights come on. Hook up jumper cables and it cranks immediately, like there was never a problem. If i keep cranking/turning off/restarting, after 6-8 times it won't crank anymore unless I jump it or let it sit 15-30 minutes. Battery was tested and is holding a full charge. Battery and starter connections are tight. Condition happens whether engine is cold or hot. Electric gremlins are definitely not my specialty. Thanks.
Old Nov 28, 2011 | 09:38 AM
jesandrw's Avatar
Have you tested the alternator? Im not a genius with cars but Im having problems with my 96 starting right now and after testing the starter and it coming back fine im looking at the alternator..
Old Nov 28, 2011 | 10:32 AM
pordlawk's Avatar
I don't think battery would be at full charge if alternator was the problem.
Old Nov 28, 2011 | 10:43 AM
When the starter is not working, check that you are getting 12V to the small wire on the starter when the key is in the start position. You will need an assistant to do this test.
Old Nov 28, 2011 | 10:45 AM
pordlawk's Avatar
Can i do this with a test light, or do I need to verify it is 12v with a meter?
Old Nov 28, 2011 | 01:15 PM
pordlawk's Avatar
Okay, it took forever to get it to 'not' crank. Finally got it to 'not' crank after about 40 tries. Unplugged small wire to starter and test light shows it is getting power in the 'no crank' mode. Starter is 3 months old, from Advance A.P. I did notice this. When cold and choke is on, it cranks after just a slight bump of starter. After choke is off, it takes a little more starter to crank it. Sometimes after constant restarting, it will die immediately after starting, like it still needs choke, and doesn't restart easily. Turns over, just won't start. When I run the starter more than just a bump, for 3-4 times, that seems to be when the 'no crank' thing starts.
Old Nov 28, 2011 | 04:37 PM
This sounds like a problem with the starter. Sometimes a remanufactured starter can fail. If it has a warranty, I would get another one.
Old Nov 28, 2011 | 04:54 PM
pordlawk's Avatar
It was a reman. starter. Advance gave me another one on my word that it was getting power but sometimes not working. R/R is a pain. That rear bolt, jeez. Everything seems fine for now. Thanks, PA, for pointing me in the right direction.
mattcadieux1
May 8, 2013 08:45 PM
opaque
Apr 22, 2013 12:17 AM
SlyBlackDragon
Jan 6, 2012 10:13 PM
libra2458
Sep 12, 2011 06:38 PM
5.0stang
Jul 23, 2009 07:24 PM
