96 EX Sedan 4cyl rear axle nut -- 22m or 24mm?
I just ordered the replacement hub/bearing, but every site I have looked at shows both 22m and 24mm nuts as options for the rear (not front) for my VIN.
1996 Accord EX 4cyl F22B1 w/ rear disc brakes and ABS Rear axle nut thread size: 22m or 24mm ? Does anyone know for a fact which size it is? I just ordered the hub/bearing replacement, am not in a position to pop the cap off before I do the work this weekend. Thanks. John |
I show a 22 mm, 134 ft. lbs. of torque.
2 Attachment(s)
where did you see that? Every reference I've see shows either/or ... e.g.
https://www.hondaaccordforum.com/for...1&d=1455657970 |
From what I can tell, the KH is for China and South American cars. Unless you're there use the 22 mm spindle nut. I got the info out of a US factory manual. It did not have the KH designation.
