96 V6 accord put on a/c belt
Old May 12, 2006 | 04:22 PM
latoilette's Avatar
Default 96 V6 accord put on a/c belt
I am having a difficult time putting a/c belt on the motor.
height adjustment bolt is there, but it won't change the height.
there is a bolt that's holding the tensioner, but it's impossible to get loose.
is there a trick or a whole new way of installing belts on hondas?
Old May 12, 2006 | 04:39 PM
sir_nasty's Avatar
Default RE: 96 V6 accord put on a/c belt
I haven't personally done a belt change on that year or model but I believe the belt runs around the alternator as well correct? If that's the case then loosen up the adjusting bolt on the alternator and the lower bolt as well and just push the alternator into a postion where the belt goes slack enough to replace
Old May 12, 2006 | 06:02 PM
latoilette's Avatar
no it does not. a/c belt is connected to crank, tensioner, and a/c compressor.
alternator and power steering is driven by another belt
it seems like no one has 96 model with V6 engine
Old May 12, 2006 | 08:38 PM
sir_nasty's Avatar
can you get/take any pictures? have you tried spraying the tensioner bolt with some wd-40?
Old May 12, 2006 | 09:53 PM
Chiovnidca's Avatar
ORIGINAL: latoilette
Your have to get the nut loose so that it will move.
Old May 13, 2006 | 01:14 AM
deserthonda's Avatar
you need to ,, first of all loosen up the 14mm nut in the middle of the idler pulley , once that 's loose, unscrew the bolt on top of pulley i believe it might be 10mm .. go as far as you need to , so you can install the new belt ,, once installed, adjust the tension by tightening the 10mm bolt,, when properly adjusted retightem the 14mm nut on the idler pulley,,
Old May 16, 2006 | 12:27 PM
latoilette's Avatar
Got it. Thanks all.
Old May 16, 2006 | 08:17 PM
lightshow's Avatar
a+
Old May 17, 2006 | 02:35 AM
glad that you got it done //
StatzFinest
Feb 10, 2008 11:32 AM
ally
Jan 22, 2008 03:09 AM
lotaboost
Dec 30, 2007 02:14 AM
junkboy
Oct 16, 2007 01:58 PM
HondaRacer4Vtec
Feb 21, 2007 08:37 PM
