97 4cyl vtech ex-- Transmission range sensor
Hi everyone I could use your advice.
I have been having transmission issues. It seem to tour throw itself in Limp Mode after about 10 to 15 minutes of driving then it will not go anywhere until I turn car off wait a few minutes. This is what I know and have done so far:
1. Replaced both solenoids. ( had code and flashing D4)
2. Changed transfer fluid.
3. Replaced radiator fan ( it was burnt out and thought maybe Trans was gettin to hot)
All with no results. Now I get a P0705 CODE about the transmission range sensor circuit malfunction(2posi). I haveven already had some excellent help on another thread but I'm putting this one out also.
I have cleaned the G101 ground on another guys advice no luck. Can this trans sensor be replaced OR should I replace the PCM at this point.
I also have a P0141 oxygen sensor heater code. Just want to be thoroughly even though I was told this has nothing to do with my current problem.
scrapmetaljoe
Aug 29, 2015 09:03 AM
