97 Accord Code
Old Jul 1, 2012 | 12:14 PM
rm162's Avatar
Default 97 Accord Code
My Check Engine light illuminated and the D4 light blinks on my '97 Accord. I plugged a paperclip into the two prong outlet under the glove box. I rec'd the following blinking lights
Check Engine 7 short blinks
D4 9 short blinks
Please help me figure out the code and the issue.
Old Jul 1, 2012 | 12:58 PM
Moved to the proper section.
ECU/CEL - 7 is for the TPS
TCU/D4 - is for the Counter shaft or transmission speed pulse generator open or shorted.
For the future. In this thread - at the top of this section, General Tech - has a lot of information:
https://www.hondaaccordforum.com/for...threads-40780/
Thanks for joining HAF
EDIT: If you can stop a parts store (autozone or other) they will scan for codes for free. The OBD-II codes they get ("P" and four digits) give a better clue as to what the issue might be. So get the actual code from them - not their description - and we might be able to norrow this down even more.
Old Jul 1, 2012 | 01:04 PM
Your 97 also has the OBD-II diagnostic port behind the ash tray. Suggest going to Autozone, O'reilly's, etc. to get the trouble code(s) read.
OBD-II diagnostic trouble codes are more extensive and may help more narrowly define the trouble area(s) .
Khai Son
Mar 14, 2012 11:32 PM
Rtherres
Jan 30, 2011 04:58 PM
will'i'am
Sep 16, 2010 01:19 PM
Stener75
Jul 25, 2010 08:21 PM
madsteez
Jan 18, 2009 07:43 PM
