97 Accord f22 vtec automatic coolant issues
I have a main issue when I would start the car. It would spin over just fine, but sometimes it wouldn't start because it would flood itself. Brand new spark plugs rusted within 4 months. Bled the coolant system more than a hand full of times, but it continues to build pressure. I even changed the radiator cap. When I press the gas to speed up, my temp gauge rises all the way, especially when I'm idling. Then all my coolant dumps into reservoir. Compression is about an even 120 across, and my fluids are not mixing.
List of things done: Distributer cap Rotor button Radiator cap Spark plugs Fresh oil change New starter New thermostat Multiple coolant bleeds All advice and opinions welcome. |
How and where did the spark plugs rust? Was it only one plug or all of them?
If you performed compression test correctly, all your compressions are below minimum (135 psi) indicating engine wear, valves leaking, head gasket leak, or all of these.
A leakdown test would disclose where compression is being lost; rings, valves, cooling sytem. Runup in temp under load and coolant push into reservoir suggests hot gas leaking into cooling system. good luck |
Originally Posted by PAhonda
(Post 352414)
Diode ?
When you did the compression test, did you floor the gas pedal? Also unplug the distributor and pull the fuse for the fuel pump.
Originally Posted by JimBlake
(Post 352439)
Diode ?
(Post 352447)
| All times are GMT -5. The time now is 02:58 AM. |
