97 Accord leaking oil
Ok so here's the story. You're welcome to laugh all you want, as I made a dumb mistake. So like 3 weeks ago I changed my oil by myself for the first time, and it was pretty easy. Although, I accidentally overfilled the oil by about half a quart. I continued to drive the car with the oil overfilled for about a week hoping that it would just burn off (Great idk btw, NOT!). Then, since it was pushing oil out of the oil cap on the top of the engine I decided to actually drain some oil out to normal level. Now it has been a full week and it is still dripping oil from the passengers side. It's not leaking from anywhere else that I can tell though. It looks like it's leaking out somewhere near the distributor/engine mount. I can't for the life of me figure out exactly where it's coming from though. Do you have any thoughts of where it might be leaking from? I'm sure I just broke a seal somewhere but I don't know where...
Four or six cylinder?
...accidentally overfilled the oil by about half a quart...it was pushing oil out of the oil cap on the top of the engine... Clean off the engine and find the leak. |
Originally Posted by Roader
(Post 279387)
Four or six cylinder?Not a problem on a four cylinder, I do it all the time due to oil burning. 1/2 qt. over won't cause oil to push out of anywhere; it won't hurt a thing.
F22B6 in his signature, so it's a 4-cyl. Overfilling like that isn't the best thing, but it won't cause the leak you're saying.
Still, clean it off & pinpoint the location it's leaking from. You think it's right where the distributor mounts against the engine? There's an O-ring in there, you can replace that. If it's leaking INSIDE the distributor, dripping out from the distributor cap, that's a different story. |
Oil fill cap is way up top on the valve cover. You sure you didn't lose the gasket for that cap?
:( just went and felt under the cap of the distributor and wasn't to happy about what I found...it's leaking a few drops from inside the distributor every time I park! How expensive is this gonna be...
I found a thread on how to replace the outer and inner seal of the distributor. I already ordered my new seals for $25. Wish me luck.
Originally Posted by Cody_754
(Post 279391)
Well obviously it was pushing out because before I drained some out it was coming out of the oil cap and now it's not.
The outer O-ring is the easier fix. I haven't had one of mine leak inside the distributor, so I can't help much on that.
just to 2x what other people have said, I have overfilled not only this Honda but other cars and 1/2 quart will not do anything.
