97 Accord leaking oil
Old Apr 30, 2012 | 04:17 PM
Cody_754's Avatar
Almost A Senior Member
Default 97 Accord leaking oil
Ok so here's the story. You're welcome to laugh all you want, as I made a dumb mistake. So like 3 weeks ago I changed my oil by myself for the first time, and it was pretty easy. Although, I accidentally overfilled the oil by about half a quart. I continued to drive the car with the oil overfilled for about a week hoping that it would just burn off (Great idk btw, NOT!). Then, since it was pushing oil out of the oil cap on the top of the engine I decided to actually drain some oil out to normal level. Now it has been a full week and it is still dripping oil from the passengers side. It's not leaking from anywhere else that I can tell though. It looks like it's leaking out somewhere near the distributor/engine mount. I can't for the life of me figure out exactly where it's coming from though. Do you have any thoughts of where it might be leaking from? I'm sure I just broke a seal somewhere but I don't know where...
Old Apr 30, 2012 | 04:57 PM
Roader's Avatar
Four or six cylinder?
...accidentally overfilled the oil by about half a quart...it was pushing oil out of the oil cap on the top of the engine...
Not a problem on a four cylinder, I do it all the time due to oil burning. 1/2 qt. over won't cause oil to push out of anywhere; it won't hurt a thing.
Clean off the engine and find the leak.
Old Apr 30, 2012 | 05:12 PM
Cody_754's Avatar
Originally Posted by Roader
Four or six cylinder?Not a problem on a four cylinder, I do it all the time due to oil burning. 1/2 qt. over won't cause oil to push out of anywhere; it won't hurt a thing.
Well obviously it was pushing out because before I drained some out it was coming out of the oil cap and now it's not.
Old Apr 30, 2012 | 05:19 PM
F22B6 in his signature, so it's a 4-cyl. Overfilling like that isn't the best thing, but it won't cause the leak you're saying.
Still, clean it off & pinpoint the location it's leaking from. You think it's right where the distributor mounts against the engine? There's an O-ring in there, you can replace that.
If it's leaking INSIDE the distributor, dripping out from the distributor cap, that's a different story.
Old Apr 30, 2012 | 05:21 PM
Oil fill cap is way up top on the valve cover. You sure you didn't lose the gasket for that cap?
Old Apr 30, 2012 | 05:38 PM
Cody_754's Avatar
just went and felt under the cap of the distributor and wasn't to happy about what I found...it's leaking a few drops from inside the distributor every time I park! How expensive is this gonna be...
Old Apr 30, 2012 | 07:33 PM
Cody_754's Avatar
I found a thread on how to replace the outer and inner seal of the distributor. I already ordered my new seals for $25. Wish me luck.
Old Apr 30, 2012 | 08:39 PM
Roader's Avatar
I'm guessing it would have to overfilled by gallons for that to happen. If that's the case then, yes, you'll have seals popping. Good luck fixing your distributor.
Old May 1, 2012 | 12:05 PM
The outer O-ring is the easier fix. I haven't had one of mine leak inside the distributor, so I can't help much on that.
Old May 1, 2012 | 01:21 PM
crispin's Avatar
just to 2x what other people have said, I have overfilled not only this Honda but other cars and 1/2 quart will not do anything.
Bovice501
Sep 17, 2012 08:52 PM
BlackHoleAccord
Jul 11, 2012 12:35 AM
kyleshondar
Jan 23, 2011 08:18 PM
churritos567
Oct 14, 2010 08:36 PM
BenJoeM
Jul 7, 2010 05:39 PM
