97 accord lx v6 front left wheel noise
Old Dec 10, 2011 | 09:33 AM
bbugara's Avatar
Default 97 accord lx v6 front left wheel noise
hello, i have a 97 accord lx v6 160k miles with 4 brand new tires, 2 new ball joints in the front, 2 new wheel bearings in the front, new brake pads and rotors in the front and i am hearing a squeaking noise from the front left tire only when i turn the wheel to the right. It does not happen at high speeds (above 30mph) but will always make a noise when i turn the wheel to the right at low speeds. I have heard the noise before the new tires and wheel bearings were put on as a repair shop told me the wheel bearings were the problem.
Any suggestions? thanks
Old Dec 10, 2011 | 09:34 AM
bbugara's Avatar
I have also replaced the lower control arm for the front left, possibly replace the upper control arm?
Old Dec 10, 2011 | 12:32 PM
You could throw parts at it all day. Suggest trying to find the source, could be in the upper control arm bushings, sway bar, sway bar links. Can the nosie be re-produced by pushing down or up on the fender?
Old Dec 10, 2011 | 12:39 PM
Search for v=scFbb43fwqk on YouTube for a good video on how to find a noise in your suspension.
Old Dec 10, 2011 | 02:47 PM
bbugara's Avatar
no noise when pushing down on fender, i replaced the sway bar and links, could be the bushings
Old Dec 10, 2011 | 06:32 PM
joec44's Avatar
Check the dust shield behind the roter when you turn the wheel the roter will flex and hit the dust shield and make noise
ericvand96
Feb 24, 2014 11:19 AM
NicaMil
Jan 29, 2011 11:29 PM
DAMc
Nov 12, 2009 05:54 PM
joncnca
Aug 15, 2009 09:12 PM
indy49
Dec 5, 2008 10:56 AM
