97 accord shakes in cold weather
Old Aug 31, 2017 | 11:57 AM
acrx7's Avatar
Default 97 accord shakes in cold weather
HI guys !! new here and owning a Honda Accord , I have a 97 accord 210k miles auto vtec 2.2l , I notice when is cold the idle is rough or shakes but in hot weather is not as rough it does at idle in gear but if I shift to neutral its smooth, also when I turn on the ac the rpms drop very low probably in to 500 or less , also when I shift in to any gear the tranny shifts hard and when driving it shift somewhat hard never smooth , the tranny was replace and I guess it came from Japan , any suggestions will be very appreciated :-)
Thank you
Old Sep 2, 2017 | 05:52 AM
The IACV can get dirty over time, you could pull it and give it a good cleaning.
For the trans, I'd check the throttle control cable - this cable runs from the throttle body to the trans - for proper adjustment/play. This is assuming that there is not an issue with any of the mounts (engine/trans).
Old Sep 3, 2017 | 06:22 PM
UhOh's Avatar
Originally Posted by acrx7
HI guys !! new here and owning a Honda Accord - 97 accord 210k miles auto ... also when I shift in to any gear the tranny shifts hard and when driving it shift somewhat hard never smooth ,
My '97 275,000 on chassis, on 2nd engine, I've owned for last 90,000 miles.
Tranny always shifts hard from one gear to next. Try to get used to it.
Old Sep 5, 2017 | 02:12 PM
acrx7's Avatar
Thank you poorman212 and UhOn ! :-)
Old Sep 5, 2017 | 03:52 PM
Being a 3-pedal guy, this is not from personal experience... But I recall some people saying that using non-Honda ATF can cause harsh shifting. Maybe a couple drain/fill cycles with Honda fluid??
(Don't use that as an excuse to ignore checking the cable that Poorman said)
Also the rear engine mount (down low between the trans & firewall) is vacuum-operated. It has a solenoid valve & some vacuum tubing - check that stuff for anything broken, disconnected, leaking, or ???
Old Sep 6, 2017 | 10:25 AM
acrx7's Avatar
Thank you JimBlake , I know the guy that had it before replace all of the mounts and fluid with Honda parts ,but I will check all of the mounts .
Thank you :-)
d0n
Dec 10, 2014 07:42 AM
jyaj2k
May 2, 2012 09:05 AM
remgene
Jan 5, 2012 11:50 AM
indy49
Nov 12, 2008 08:47 AM
AccordEX
Dec 4, 2006 02:09 AM
