97 accord v6 auto jumpy tach video
Old Apr 18, 2014 | 03:16 PM
TexomaAccord's Avatar
Default 97 accord v6 auto jumpy tach video
97 accord v6 automatic
After it warms up it starts jumping around.
No engine surges or anything. Runs normal, just jumpy tach
Ideas?
Old Apr 18, 2014 | 04:01 PM
This could be a problem with the gauge itself, or the tachometer signal.
The 97 V6 accord gets the tachometer signal from the coil. Id check the electrical connector for the coil first to make sure there is no corrosion and you are getting good contact.
Old Apr 18, 2014 | 06:30 PM
High probability it is due to something associated with the ignition coil.
Old Apr 18, 2014 | 06:38 PM
If it was the ignition coil, wouldn't it affect the way the car is running?
Someone said something about a blue wire??
Why did I buy a Honda? lol
I love my american cars
Old Apr 18, 2014 | 06:59 PM
It's usually due to a faulty resistor in the ignition coil. A faulty resistor doesn't affect the coil’s ignition functions.
There was a July 2001 Honda Service News article on it many years ago:
Tach Fluctuation and/or A/T
DTC P0725: Accord V6
On ’95-97 Accord V6s, when you troubleshoot a
fluctuating tachometer or A/T DTC P0725 (lockup
clutch does not engage), keep in mind the
cause could be a faulty resistor in the ignition coil.
The transmission control module (TCM) provides
electrical pulses through this resistor to drive the
tachometer.
Although a faulty resistor doesn’t affect the coil’s
ignition functions, you’ll still need to replace the
ignition coil to fix a fluctuating tachometer or A/T
DTC P0725 - the coil resistor isn’t available
separately. Order P/N 30520-P0G-A02, H/C
4598371, for the ignition coil.
Old Apr 18, 2014 | 07:11 PM
You have to take into consideration the car is 17 years old.
Old Apr 18, 2014 | 08:22 PM
And my american car is 48 years old
Thanks for the info, I'll look into the wires and then look into getting a coil, shame I can't get a resistor
Ah well, with all the help I'm getting on these forums since joining, this thing will be running much better!
Thanks again
Old May 19, 2014 | 10:06 PM
I still haven't looked into the tach wire yet.. GF drives the car all the time and I get busy.. When I drive it, I find myself watching the tach instead of the road lol
Old May 20, 2014 | 01:45 PM
19962door's Avatar
I have a 1996 Accord LX, and have also had tachometer issues.
On several occasions, the tachometer has stopped working for a period of time. Each time, I was lucky and the tach started working again.
I've also had "shaky tachometer" issues, which preceded the tachometer not working.
When you get the problem solved, please let us know.
Thanks,
Rob
Old May 20, 2014 | 01:53 PM
Thanks,
Rob
The engine speed output signal for the tach on a 4 cylinder is different than a 6 cylinder.
The engine speed output for a 4 cylinder is from the ignition control module (ICM), which is inside the distributor.
