98 Accord Dies after startup/Cylinder misfire code
Old Feb 15, 2011 | 01:07 PM
bobrae2011's Avatar
Default 98 Accord Dies after startup/Cylinder misfire code
I have a 1998 Accord Ex Coupe. Has about 270,000 km on it.
Recently ive been having this problem with starting up.
What happens is when I start the car the rpm idles very low (car shakes more than normal) and dies unless I push and hold the gas. If I push the gas and hold the rpm high, the idle will become normal after 30 seconds of so.
This issue only happens around 1 out of 10 times of starting the engine. 9 out of 10 times it starts fine.
After the last time this happened, my engine light came on. The error is "Cylinder Misfire".
After reading some forums, it sounds like it could be the following:
- Bad spark plug wires
- Distributor cap
- Egr port needs to be cleaned
- Fuel pump
If anyone has any ideas about this, I would appreciate your advise.
Thank you
Old Feb 15, 2011 | 03:23 PM
V-6 or 4-cyl??
How old are the spark plugs? What brand? (NGK I hope)
Remove the sparkplug wires & look for oil down in the sparkplug tubes. If so, replace the valve cover gasket set.
You can check for bad plug wires or distributor cap by starting it cold, in complete darkness, & look for arcing. Even a dull blue glow would indicate bad component (whatever is glowing).
Old Aug 4, 2012 | 08:06 AM
98accordsedan's Avatar
I too have the problem. I have a 98 accord sedan. 4 cylinder. At 163k. My car had always had problems running correctly. It has multiple misfires, and I have to rev my car in order to get it going on first gear and reverse. It also lags a lot, seems like the air is not flowing right. When it first starts up correctly, it drives normal but when I get to 2nd gear and up, it starts to choke and power is not there. Rpm won't go past 4000 -5000. I have a video of how it starts up. My maintenance lights flashes for four to five seconds then disappears. I flushed my training oil and change my oil on a regular base 3kmiles. Anyone have an idea wgat to do? Here are my OEM codes
P0131
P0171
P0303
P0304
P0300
P1456
P0133
P1129
http://static.photobucket.com/player...804_064710.mp4
Im a noob. And if you have any idea if what will be an easy swap, lmk I might just swap it instead. Thanks in advance.
Old Aug 4, 2012 | 09:32 AM
doctorbee's Avatar
reset them all and read it as soon as the light comes on
Old Aug 4, 2012 | 10:43 AM
Looks like a mess of codes (o2, evap, map and misfire).
When was the last tune up done?
Old Aug 4, 2012 | 02:30 PM
Last year. Changed spark plugs, spark plug wires, even had to change distributor because the teeth on it broke.
It ran the same as before thd change.
Old Aug 5, 2012 | 06:10 AM
I look into cleaning the egr port in the intake. Might clean the vavle while you are there.
Also test the O2 sensor and replace if needed.
Old Aug 5, 2012 | 09:35 AM
doctorbee's Avatar
Reset and re read to narrow the problem
Stimn11
Dec 15, 2012 03:59 PM
jacksprat
Sep 7, 2012 04:55 PM
HashGobbler420
Jun 8, 2012 07:00 PM
murphyje
Jun 1, 2011 06:48 PM
crazy3rdgen
Apr 4, 2011 11:31 AM
