98 accord ex/cl swap
Old Oct 6, 2009 | 12:54 PM
accordexswap
Default 98 accord ex/cl swap
I changed the throttle body and thermostat and now it wont start. the motor turns but it sounds like its not getting fuel.... the green security key has not stopped flashing and i am wondering if this is the factory starter kill? Plz help
Old Oct 6, 2009 | 02:17 PM
Look for wires you forgot to re-connect?
Cluster of ground wires near the thermostat housing?
Check for spark.
Spray TB cleaner into the TB & see if it fires up for a couple seconds.
Old Oct 6, 2009 | 02:37 PM
accordexswap
the security key light is still flashing how can i shut that off?
Old Oct 6, 2009 | 04:08 PM
Not sure how that would be related to the thermostat. I thought that system was just between the ECU and the RFID antenna at the ignition switch. Did you do anything around the steering column? Center console where the ECU lives?
Old Oct 6, 2009 | 09:57 PM
accordexswap
no but when i disconnected the battery terminal i dont think i did it in the right sequence..
Old Oct 7, 2009 | 09:05 AM
Explain that a little more. The only thing I can think of is shorting something & blowing fuses. Your '98 has fuses all over the place. Fusebox in the engine compartment. Additional ones in BOTH ends of the dashboard, alongside the door hinges.
Old Oct 7, 2009 | 05:53 PM
finch13's Avatar
What did you swap in? If you got new keys or an ECU, they need to be programmed to match each other. The security light is saying that you do not have the proper key matched to the computer and it will not start.
Old Oct 8, 2009 | 07:06 AM
Throttle body & thermostat have nothng to do with the immobilizer.
If the engine & ECU were just swapped, that's an entirely different story.
Jrmemo
Jan 27, 2013 07:41 PM
hondahead23
May 9, 2011 08:55 AM
mfskarphedin
Jun 6, 2010 09:33 PM
StatzFinest
Feb 10, 2008 11:32 AM
