98 Accord EX oxygen sensors identical?
Old May 26, 2013 | 08:37 PM
Airdorn's Avatar
Default 98 Accord EX oxygen sensors identical?
Hi,
Are the two oxygen sensors around the catalytic converter exactly the same part? If so, I think I will swap them to see if the problem follows the swap, or stays at the rear sensor.
If the former, I'd know I have a bad sensor. If the latter, I'd know it's a bad CC.
Amirite?
Old May 27, 2013 | 08:08 AM
If you get a universal one, you have to splice the wires...they are the same.
Old May 27, 2013 | 09:30 AM
Airdorn's Avatar
Thanks but does anyone know for sure if the oxygen sensors on this 98 Accord are the same part? As in the same part number.
I keep seeing differentiation between them at places like Autozone... they call one "upstream sensor" and the other one "downstream sensor"...
If they aren't the same part, then I can't swap them for testing.
Old May 27, 2013 | 10:02 AM
O2 sensors are likely same (4-wire sensors), however harness lengths and bulkhead grommets (on harness) are likely in different positions.
Check majestichonda.com for part nos. If different part no, part is different. You may be able to visually determine from graphic of parts.
Old May 27, 2013 | 10:03 AM
Silver6gen's Avatar
F23a1 has two narrow band sensors
F23a4 has an upstream wideband sensor and a downstream narrow band sensor.
They might not be the same part number but if you have the F23a1 then it doesn't matter. If they want something like 200-300 for the sensor then they have probably looked up the wideband.
Old May 27, 2013 | 10:43 AM
Yes, I assumed the OP's car had an O2 and not an Air/Fuelt sensor (wide band).
According to Denso's site the universal (no pig tail) is the same part number for the upstream and down stream.....again you have to splice the wires.
Old May 27, 2013 | 12:41 PM
Airdorn's Avatar
F23a1 ...... how do I find out if that is my engine? Is there a sticker somewhere on the car that says "I am an F23a1!" ?
I have a 98 Accord EX 4-cylinder
Old May 27, 2013 | 12:51 PM
You can put your cars VIN into one of the many online honda dealers sites (majestic, bernardi, ect) and look up the o2.
Pretty sure there is a stamping on the engine block with the info.
Also I think the valve cover has something like SLEV on it?
I added some info to my post before about the O2, denso has the universal the same for the non SLEV (non air/fuel) o2's front and rear.
Deckj0122
Jan 8, 2011 10:34 AM
edtheace
Dec 29, 2010 08:37 PM
cleerios
Jan 16, 2009 12:36 PM
DMN_RITE
Apr 20, 2007 03:27 AM
Rasher
May 17, 2005 01:19 AM
