98 Accord, no 2nd gear, help
Old Jan 23, 2009 | 08:06 AM
Lance's Avatar
Default 98 Accord, no 2nd gear, help
new guy here, I have a 98 Accord EX. its an auto. there is no 2nd gear whatsoever. it will shift into 2nd but it feels like neutral. all the other gears work fine. so far I have changed the shift solenoid B on the trans but that didn't help. does anyone know what voltage is going to the solenoids so I can check if the TCM is doing what its supposed to? or maybe some kind of better troubleshooting method?
thanks!
Lance
Old Jan 23, 2009 | 03:42 PM
Default RE: 98 Accord, no 2nd gear, help
Check whether there are any OBD1 trans codes even if D4 light is not blinking. Short service check connector and read flashing D4 light. Some trans codes don't set the D4 light flashing, but are caused by simple electrical faults. I know this was true until 97 model, but not sure about 98.
Old Jan 23, 2009 | 07:08 PM
Lance's Avatar
if there are codes, how do I know what they mean? is there a link to a page with codes for the 98 with their translations?
Old Jan 23, 2009 | 09:10 PM
Your car is OBD II, so you would have to stop by an autozone and have them read the codes. Post on here (P####). You can also find a lot of info by just by a google search with the code and your car.
Old Jan 23, 2009 | 09:57 PM
Lance's Avatar
no Autozone in Guam haha. I will go see if it puts out any codes
Old Jan 24, 2009 | 06:52 AM
The 96-97 Accords have Obd2 and Obd1 capability. Does the 98 only have obd2? If both, you can extract code manually.
Old Jan 25, 2009 | 05:59 AM
Lance's Avatar
I can't' find a 2 prong connector under the passenger side dash. how do I get it to put codes out? there is a 16 pin under the drivers side though...
Old Jan 25, 2009 | 08:06 AM
As I said, I don't know for sure that 98 has obd1. In earlier models the two wire connnector is plugged into a dummy blue plastic holder along w/ another plug. The blue plastic holder is pinned to the cross brace that supports the glove box. Unplug the 2-wire connector by pinching and pulling to remove from holder.
There is a DIY instruction on extracting codes, but in summary; short two wires w/ paper clip, etc; turn keyswitch to ON, and read flashes of the Check Engine Light (long flash = 10's digit, short flash= units digit, and short pause between 1st-2nd digits. Example F-p-f = 11. There may be more than one code which will be separated bya 4-5 sec pause between codes, or same code will repeat 3 times.
Old Jan 25, 2009 | 07:51 PM
My 98 did NOT have the OBD-1 connector.
Old Jan 26, 2009 | 12:02 PM
W/O an OBD1 connector, you will have to purchase or borrow an OBD2 code reader. They can be purchased inexpensively in US, not sure about Guam. Once you have codes, put them in a response to the forum and someone will help.
