98 Accord V3.0, Re-Starting after Driving Problems
Car: 98 Accord Ex 2-Dr V-Tech 3.0, 160k,
Problem: Intermittant re-Starting problem, only after after driving Occurs maybe 5-10% of the time when tried restarting Starter Cranks fine, turns engine fast, no warning lights, full tanks to 1/4 Background: Owned for 1.5 years and started noticing problem last summaer (9 months ago) Starts 1st Time after Over-night sitting Now and then will not re-start after driving. Let the car sit >30 min and fire's up in 1-2 sec Noticed mainly during 'Hot / High Sun Exposure', But today after morning drive for 12 min would not re-start (temp 30F) until it sat for > 30 min. Then restarted fine and within 1-2 sec of cranking. And re-started, restarted, ... atleast 10 trys no further problems To-Do: Have searched the HAF and will double check Fuel Cap, Fuel Pump & Relays Also will check Plugs, Coil, Dist caps, .. the simple basic stuff Take to Parts House for Fault Code Check But did notice 1 thing from under-hood check the IAT Sensor is 'Wet' fairly clean looking oil, will spend some time to check the threads / seal or sensor cracked. Any other focus Debugging Steps would be appreciated tks |
Sounds like you are on your way.....kind of sounds like the main relay but that is why we have to test things :) Good luck and let us know what you find.
