98 Honda Accord V6 Alarm Question
Old Feb 4, 2013 | 10:47 PM
my986thgen's Avatar
Post 98 Honda Accord V6 Alarm Question
Does any one have a step by step on reprogramming the remote and putting the factory alarm in valet mode? any help would be greatly appreciated.
Old Feb 5, 2013 | 07:15 PM
A friend of mine posted this a while back.....see if it helps:
http://www.tegger.com/hondafaq/misc/98-011.pdf
Old Feb 10, 2013 | 01:31 PM
my986thgen's Avatar
this helps with the programming side but doesn't help put it into valet mode
Old Feb 10, 2013 | 02:27 PM
Try this and report back if it works or not.
To place in Valet mode:
1. Disarm the system.
2. With the key out of the ignition, press and hold the Disarm/Valet switch for more than 3 seconds.
3. The status LED will flash once, indicating that the system is in Valet mode.
Note: If a door is opened or the ignition key is removed while the system is in valet mode, the status LED will illuminate for 2 seconds as a reminder that the system is in valet mode.
______________________________________
To Exit from Valet mode:
1. With the system in Valet mode and the key out of the ignition, press and hold the Disarm/Valet switch for more than 3 seconds.
2. The status LED will flash twice, indicating the system is out of Valet mode.
3. The system is now in the Disarm mode.
Old Feb 10, 2013 | 09:14 PM
my986thgen's Avatar
have no idea where thee valet button on my 98 accord it is a factory alarm
Old Feb 10, 2013 | 10:34 PM
Is there a button on the under dash panel?
Old Feb 10, 2013 | 11:00 PM
my986thgen's Avatar
not that I now of I will check it tomarrow
Old Feb 11, 2013 | 07:23 AM
Was the 1998 V-6 alarm different from the 4-cyl? I had a 98 EX 4-cyl and there wasn't any valet button. Use the valet key to lock & unlock the door and the alarm sets itself. Only difference is the valet key won't open the trunk or glovebox.
Old Feb 11, 2013 | 09:49 AM
The circuit diagrams does not show any differentiation for the EX security system for V6 and 4-cyl. It shows a different circuit for the LX. I couldn't find anything in the 98 Accord owner's manual regarding the EX security system. The instructions I posted were from the security system owner's manual for the Honda accessory security system.
Your instructions regarding the valet key should be correct for the EX.
Old Feb 11, 2013 | 11:15 AM
OK, mine was a factory standard alarm in the EX. Sounds like the dealer-installed accessory alarm was different? That rings a bell.
(Memory like a steel trap - rusted shut)
