'99 accord
Old Apr 27, 2012 | 11:37 PM
crosed's Avatar
Default '99 accord
Hi everybody..
i just join tonight..
i have 99 accord lx
but in problem now..
i want to know about my problem
my transmission is leaking after the car run,but only 1 until 3 tick only..
at the whole night only 1 to 3 tick only..
only after car running..
i dont know what happen with this case..i changed the axle seal already,but it's not work..
is this carrier bearing?
anyone have the same case with me?
Old Apr 28, 2012 | 07:05 AM
Is it leaking from the axle seal? Clean it up so you can watch and pinpoint the locations where it's leaking from.
Old Apr 28, 2012 | 07:46 AM
crispin's Avatar
I had a thread on this recently.
I was getting a leak from the axle seal as well.
I changed the axle seal and still had the leak.
I was told it was the carrier bearing however I wanted to try something easier first.
I changed the axle (and installed another new seal) and that fixed it.
My old axle must of had a slight wobble to it which caused the fluid to leak past the seal.
Mine is leak free now.
Old May 2, 2012 | 10:23 PM
crosed's Avatar
thx for sharing..i changed the axle..and i think it work..because i drive 160 miles and i check no leak again..
but after i changed the axle,when i drive in 20-40 mph,there is shaking..what should i do?balancing or aligment?
Old May 3, 2012 | 12:03 AM
deserthonda's Avatar
shake when you accelerate ?? if so , could be a bad inner cv joint ,First of all double chk your work make sure everything is properly installed and all the bolts are tight , chk the tires as well,,, and make sure that there are no worn frt suspension parts
it is not alignment issue ,, and out of balance usually happens at hwy speeds ( over 50 )
Old May 3, 2012 | 07:37 AM
crispin's Avatar
there have been reports that the cheaper axles (the ones under $100) sometimes have a shake to them.
If the shake bothers you then you could take the axle out and bring it back and swap it for another one.
Old May 3, 2012 | 10:20 PM
crosed's Avatar
sorry,now i know,when accelerate 20-30mph only..30mph above is none..
i not check yet..
i dont know about the axle price,because i pay $225 for labor and axle + axle seal..
so confuse..
Old May 4, 2012 | 09:41 AM
crispin's Avatar
oh you paid a shop to do the work, well take it back and tell them it shakes now and it did not used to shake so they need to fix it for you.
