99 Accord 4cyl idle surge issues
Old Mar 26, 2018 | 10:47 PM
Kenny Hill's Avatar
Default 99 Accord 4cyl idle surge issues
I have a 99 Accord 4cyl 5-speed. I am having the infamous honda idle surging issues. Back story: driving down the freeway one night and started losing lights then eventually everything and left stranded on road. Took alternator in and tested fine, battery tested bad so replaced that! Now i have the battery, doors open and brake light illuminated, as well as thw idle surge from 1100-1800 while in neutral. Replaced IACV, cleaned throttle body, and intake port, pulled ECU fuse to reset. Idles fine after reseting until i put it in gear to drive and surge returns... Please Help!!!!
Old Mar 27, 2018 | 09:18 PM
rockhoundrob's Avatar
Did you do any work that required draining the coolant? If so, then you need to bleed the air out.
Old Mar 28, 2018 | 04:40 PM
irhunter's Avatar
A bad battery and good alternator should not leave you on the side of the road as you describe.
Is the CEL on?
Old Mar 29, 2018 | 02:09 PM
Kenny Hill's Avatar
I have topped off and bled the coolant system per another thread i had read, reset ECU fuse and still have the surging idle.
Only check engine light that has ever come on had to do with the IACV, which i replaced.
Still stumped and not wanting to take it to a shop. I have sprayed and checked for vacuum leaks and no results.
Any other ideas?
Old Mar 29, 2018 | 03:20 PM
The Toecutter's Avatar
Any other ideas?
Just because you replaced the IAC valve doesn't mean it's a good one. Yes, they do make bad parts.
Pull the air intake snorkel off to get to the throttle body, and plug the hole feeding the IAC air and see if it stops the surging. If that doesn't work...
Try turning the AC on high, and see if it still surges. If it stops, then replace the valve. If not, you'll need to do more searching.
Old Mar 29, 2018 | 09:58 PM
Kenny Hill's Avatar
i will try that and update, thanks!
Old Mar 30, 2018 | 05:50 AM
Have you tried adjusting the base idle then forcing it to "re-learn" the idle? Try this...
https://www.hondaaccordforum.com/for...e-speed-38734/
Old Mar 31, 2018 | 02:15 PM
Kenny Hill's Avatar
So update.... the IACV seems to be opening up and fixing itself, just need to drive it more. Drive it around and when i park the idle surges two or three times and then settles down to a normal idle. Still not where i want it to be, considering i have to smog it this month. Ive adjusted the idle screw to try and level out the idle nice and smooth, beat idle i have after adjustment is about 1000-1100, sound about right?
Will start another thread on this separate question, but throwing it out in here because it started once i started having this idle issue. So my doors open, battery, and brake lights are staying illuminated on the dash all the time. Any ideas of how to fix it?
Old Mar 31, 2018 | 02:40 PM
Idle speed when warm is 750 rpms.
Old Mar 31, 2018 | 04:41 PM
Kenny Hill's Avatar
JimBlake, I actually attempted resetting and re-learning the idle from your post, and no luck. Now that it is running a little better, i may try again
Update****
Did re-learn idle process with no luck, surge is back. Kind of frustrated now, guess im gonna have to go get the $168 IACV and start there...
