99 Accord 4dr 4cyl drivers window went down when car started won't go back up????
Old Apr 13, 2011 | 03:26 PM
engtaz's Avatar
Almost A Senior Member
Default 99 Accord 4dr 4cyl drivers window went down when car started won't go back up????
Just got into the card and started it up when the drivers window went down and won't go back up???? Any help please, on the interstate drive to destination another 3 hrs further to go in a 8 hr drive.
Thanks
Old Apr 13, 2011 | 03:43 PM
Does the window motor make any noise when you are pushing up/down? Does the window move at all? Do any of the other windows work?
You may want to check the fuse for power windows. The location should be in your owner's manual.
Old Apr 13, 2011 | 03:53 PM
engtaz's Avatar
I'm at home troubleshooting for the wife on the road with the kids. The driver side is the only problem window. It motored down but won't go up. I don't have a manual here with me.
Old Apr 13, 2011 | 04:10 PM
On my 95, my switch would not make a solid contact sometimes. I am not sure how the switches are in your 99. I would push down on the switch while pushing the switch forward to put up the window.
If any of the glass is exposed, she can try to pull the window up while pushing the switch to close.
She can try repeatedly hitting up and down on the window switch to see if the window motor can get past a possible dead spot?
Old Apr 13, 2011 | 04:21 PM
engtaz's Avatar
Thanks, I just txed her the instructions.
Old Jun 10, 2011 | 06:51 AM
engtaz's Avatar
I had a support put in for her and when she got back, I found the window regulator was bad. replacement was easy.
Thanks
Michael Bomes
Sep 9, 2012 03:12 PM
dixon2864
Jun 13, 2011 07:39 PM
hondagirlie
Jan 22, 2010 07:01 AM
phydeauxman
Sep 16, 2009 06:36 AM
LSU99
Apr 3, 2008 03:57 PM
