99 Accord EX V6 (AT) Code P0705 - New Neutral Safety Switch didn't help
Please Help! I've checked other posts but they don't address my issue.
I just installed a new Transmission Range Sensor/Neutral Safety Switch (Interstate) based on troublesome shifting and an engine code of P0705. Worked great for one day, and now my troubles have returned.:mad: What am I missing? Did I do something wrong on the install?:shrug: Original symptoms: A month ago, Accord started having hard shifts. Checked transmission fluid levels – okay w/ color a light red-brown. Shifting gradually got worse. Noticed that outside temps affected the symptoms. Below 60 degrees, the hard shifts were minor until at least 20 miles of driving.Once outside temp hit 70 degrees, shifting deteriorated within 1/2 mile, with slipping & lurching through all gears. I could minimize the lurches a bit if I eased up on the gas when shift was happening. Rough shifts (3rd to 4th) vs. full on slipping (1st to 2nd). Initial Check engine codes: (1) P0705 Transmission Range Sensor Circuit Malfunction (2) P0700 Transmission Control System Malfunction New code 4 days later: (3) P0740 transmission torque converter clutch circuit malfunction What I’ve checked/done so far:
What’s happening now: Shifting is worse than ever - especially when starting. I’m literally creeping forward until the gears engage with a heavy clunk/lurch. Have found it’s best/safest to start from D1 & work through the gears vs. leaving it in full automatic (D4). Is there anything else I can try or is the transmission done? |
Originally Posted by justonestep
(Post 372219)
Just went to remove the dual linear solenoid and got as far as loosening 2 bolts and realized I'd need a offset extension. Before even trying to disconnect the wiring, I could see the black connector was damaged, so I'm guessing this is the culprit. It's loose and clearly not attached to the solenoid like the tan one is. Can't imagine how it was damaged since it's pretty well protected by the battery plate.
Anyhow, now the D4 light is flashing - so clearly I need to get the part ordered. Can anybody direct me to a link that shows how to remove this solenoid? There are 2 hoses that will need to be removed and I'd prefer to have something to look at before I attempt this. Thanks! |
