99 Accord F23A5 SOHC non-vtec cam install
Had head resurfaced and cleaned up, and valve job done. But....it all came back to me disassembled. I've looked at the honda manual and it's pretty vague. I've mounted the head on the block, but I'm in over my head with the cam shaft. Everything was at TDC when removed, so I'm just basically re-assembling in reverse order. The difference is the cam was mounted before and now it's not.
The head is bone dry, I just want to make sure I do this right. Does anyone have a guide or walk through for this? |
All the valves should be closed with the camshaft out. Were they all closed before you installed the cylinder head?
If the valves are closed, then the crank should first be set to top dead center. Then you can put the cam sprocket on, so you can install the cam pretty close to TDC as well. I am not sure what the best way is to lubricate the dry parts while installing. You may want to call the machine shop an ask their advice on how to properly lubricate it when assembling. |
Yes, all closed. A guy I work with said the same you have. Everything was at TDC before disassembled and should still be. The machine shop did a valve service (checked for damage, adjustment and replaced stem seals) when they pressure tested and resurfaced. They also made it sound like "just line everything and torque it down". So I'm hoping that's right.
Torquing bolts on camshaft assy has a specific sequence to avoid excess bending of camshaft. There is a download manual available (Online Manuals post in DIY) for your model, but requires burning a CD as an intermediate step to access the manual.
Same info should be available in a Haynes manual. good luck |
Eric the Car Guy has a nice youtube video that includes R&R'ing the rocker assembly: wYU8qtPzQOY.
You just have to take it slow. While you're tightening the bolts valves will be opening. It's a good time to check the valve adjustment. Edit: I overlooked that the shop did a valve job...the valves have to be adjusted. |
(Post 334270)
Originally Posted by Roader
(Post 334272)
You just have to take it slow. While you're tightening the bolts valves will be opening. It's a good time to check the valve adjustment. Edit: I overlooked that the shop did a valve job...the valves have to be adjusted. Your edit, I'm not understanding. The valves now have to be adjusted? If that's the case I'm depressed! LOL. I have no cash for any more special tools. |
If the shop did a valve job then valves have to be adjusted. The valve seats and valve faces were ground which will put the valves closer to the rocker arms. Left unadjusted the valves will likely be too tight and could burn. No special tools needed. Just a feeler gauge, $4 at Harbor Freight. Eric the Car Guy has another fine video on adjusting valves: P7wI4EtZSaA
(Post 334287)
The camshaft has to be installed in order to adjust the valves. If you're installing the camshaft now, well... that's why the shop couldn't do it for you.
I'd smear some grease in the camshaft bearing journals. Better yet, some engine-assembly grease. Even a liberal pour of engine oil into those things before assembling would be good. |
